Ribbon Cables
Ribbon Cables
What sort of factors affect the performance of ribbon cable, and can you improve the electromagnetic compatibility of a ribbon cable. Can anyone suggest and good websites where I can read up on this, thank you.
RE: Ribbon Cables
RE: Ribbon Cables
If you have fast risetime signals in your cable, you may experience crosstalk between ajacent lines, reduced risetime at the other end of the cable, or EMI radiation from the cable. Reducing this begins in the design stage in assigning additional pins/wires in the cable as ground returns and to keep the impedance of the signal path somewhat constant. Even higher speeds may require more special ribbon cable in connectors, and special design techniques on the circuit ends. The issues are similar to PC board design for high speed or EMI issues. Ribbon cables with twisted pairs and with a foil shield are also made.
These topics are covered in books such as: High Speed Digital Design - A Handbook of Black Magic by Johnson.
More information on your design, and what problem you are experiencing would be helpful.
RE: Ribbon Cables
