Circulating Water Flow Switch
What is the best selection solution for a flow switch in a 30" circulating water line?
RE: Circulating Water Flow Switch
In general, I prefer to use a flow transmitter and set the switch value in a programmable system such as a PLC or DCS.
John
I prefer to use a calorimetric flow switch.  Try weber Sensors Inc  www.webersensorsinc.com and check out the model 4100 coolGuard and 4120 metering flow switches.
