Electronic Water Sensor
I am looking for an "electronic water sensor" (for lack of a better description). Basically, if it's submerged in water I want it to provide a signal, if it isn't then no signal. The depth is minimal, so using a pressure differential (probably) wouldn't work.
Anyone who knows of such a device, please let me know!
Thanks!
Thanks!
RE: Electronic Water Sensor
TTFN
Ultrasound
Laser
htt
http://
http://w
http://
Glad to help out a fellow mechanical -when it comes to electronics most of us need all the help we can get!
What about the windsheild washer sensor in my car ?
It sends a signal when the level of fluid in the tank gets lower then the position of the sensor. I imagine one could reverse it to send a signal when fluid is above the specified level.
Funny thing is, it doesn't work very well lately ...
R
http:/
optical, ultrasonic, float...choose your flavor and price.
www.gemssensors.com
good luck
You can find them in common literature put out by various electronic manufacturers. The one I had was made by RC Industries and had a beeper when the water level rose thus making contact with the sensor. If you go to Cardinal Electronics, etc, you can buy them off the self or at least get the parts to build your own. It's not tough!
Have you tried surfing the web, Google or something?
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
David Baird
mrbaird@hotmail.com
Sr Controls Engineer
EET degree.
Journeyman Electrician.
