Drawings will not insert model dimensions
Has anybody had problems having SW insert model dimensions on creation of views, we have the place dimensions inserted from model checked. What gives? SW4 sp3 win XP.
Thanks in advance.
TAP
Thanks in advance.
TAP
RE: Drawings will not insert model dimensions
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
TAP
Also, if you are using "relative to model" views, beware. Sometimes when these views are inserted they do not ask if you want projected or isometric views, and views are set to isometric without the user's knowledge. I wrote an addin to compensate for this, as we've lost many man-hours due to this.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
