Process Engineering software
Hi all, I've tried to search for this question, but as I'm new here and not sure if I know how to ask the question, please forgive if this a duplicate thread.
I'm a system analyst new to the world of Engineering. Specifically Engineering Processing. From what I gather, my company has a Hodge podge of databases, but none of them work together. So before I go and redesign their needs, I wanted to check if there are some solutions already available to look at and see if they meet our needs or can help edumacate me.
looking for way to tie together the Engineering Processing that involves:
-PDFs
-P&ID
-Equipment list
-Instrumentation list
-Motor and Electronic list
-Piping list
-Drawing list
-Line list, etc...
-Procurement Module (Bid tracking, PO, Receiving)
I just can't help but thing this has been done many times over and existing applications can handle this.
Thanks for your time!!!
-PDFs
-P&ID
-Equipment list
-Piping list
-Drawing list
-Line list, etc...
RE: Process Engineering software
(cadcentre) AVEVA VANTAGE Suite
http://www.aveva.com/engineeringit/
Bentley Plant Products
http://ww
Intergraph SmartPlant
http://ppo.intergraph.com/businesses/
All the above a large and expensive systems. It is a complex task.
But on a smaller scale my own ControlDraw may interest you.
http://www.controldraw.com
I am searching for a cheap and possibly shareware software for controling a work-shop business.
The firm is not a big one. We have 2 CNC-laths, 3-mills and some other equipment (3 universal laths, electric corrosion etc).
What I want to do is organize the business by controlling the work that has to be done, by which machine, how much time will it take ( in simple words make a schedule for the works that has to be done there ) and the ability to change some of the above info. accordingly (example: Schedule a new order that will interlude the existing ones).
If you have any suggestions please inform me.
I Lean on your help.
Best regards.
As for using the engineering data in the business processes, that is a little trickier. Bentley Systems has a product called eWarehouse that addresses the issue of tying all the information together and using it within the business processes. For more information look at www.bentley.com under Plant products.
