Part custom properties and BOM
Hello to all
I have a question about custom part properties and their use in assembly BOM.
Let's say that Part A is being used in 3 assemblies A1, A2 and A3 (for the sake of simplicity, I have taken 3 assemblies, it could be many more). Each of these assemblies contains a different number (instances) of Part A.
A1: 10 instances of Part A
A2: 5 instances of Part A
A3: 2 instances of Part A
Now when I create drawings (D1, D2, D3) for each of these 3 assemblies, each BOM should show the respective number of Part A in the Quantity column. How do I do this?
If this part was just being used in one assembly, I would create a custom property 'Quantity' for the part and make a column in BOM that would show this quantity. But how can I solve the above situation?
Thanks to all the readers.
RE: Part custom properties and BOM
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
FYI you can't hide the QTY column in the new SW BOM. So adding your own Qty Column is kind of pointless.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
It sounds like you are trying to attach QTY used as a characteristic of your part. People generally do not do this for precisely the reason you are describing above.
The quantity of your part is a characteristic of the assembly that calls it up. If there are several assemblies, each will have its own quantity, and you do not have a problem.
JHG
