Flange Design
Flange Design
Flange Design
May someone can advise what is the sect. VIII / 1 correct procedure for designing a flange opening, flash mounted on shell - Fig. UG-40 (a-2).
1. Does code permits mounting that flange type on a cylindrical shell?
2. Does thickness of the flange has to be determined acc. to Reverse Flanges calculation (App. 2-13)?
3. If so, how should I consider Hub's dimensions: h / g0 / g1?
Thank you very much for your help.
