Enclosures
Enclosures
I have been looking for an enclosure that apparently doesn't exist, but maybe it's just not on the net.What I need is something that has a clear door or window, opens to access the instrument behind the door or window, and has 7-8 inches of working space behind the face of the instrument to be mounted,but then I need to be able to access the rear of the instrument also, preferably without undoing screws, hinges are ideal here, like a swing out door. So right now I have used the Hoffman A-12106CHQRFGW with a swing out door kit, this enclosure is not deep enough, and way too big around, 12x10, I want something closer between 6x7 or 10x8 and like I said before 7-8 inches of working space behind the mounting surface of the instrument.
RE: Enclosures
"Venditori de oleum-vipera non vigere excordis populi"
RE: Enclosures
RE: Enclosures
I have an enclosure part number that might fit your job. Do a goggle search on PJ864TW. This should get you in the right area to look around.
Tofflemire
RE: Enclosures
John
RE: Enclosures
RE: Enclosures
