Concrete Software Programs
Our structural engineering department is looking for a good concrete design program. I am 3 years out of college and have not been introduced into a concrete software program, however I am leading the task for finding one.
Can I get some thoughts on particular programs that would be of benefit for flat slabs (one-way, two-way), drop panel, and even concrete joist slab designs? Currently we own a program called Adoss that is not beneficial for large scale projects. Any information on this topic that could point me in the right direction would be great.
csm
csm
RE: Concrete Software Programs
The Portland Cement Association
http://www.cement.org/
has some interesting program:
pca-mats; pca-column; pca-beam; pca-wall; pca-slab; pca-frame
All of them for design or revision of elements.
If you are looking for analysis and design for whole structures one of them may be:
Research Engineers International with the program staad-pro
www.reiworld.com
Ajose
AUCE98
RC, PT, pretensioned and Partially Prestresseed members can all be analysed and designed.
www.raptsoftware.com
However, I recommend getting together a couple of potential software titles and contact each of the developers. They will give you a short-term license or a limited capacbility package for you to try out. There is no use in spending a lot of money on a long-term license on software that you may find does not meet your needs.
