Units of Kinematic Energy
Hello all,
Somebody knows which are the units of the kinetic energy if use milimeters (mm) like length? ¿mJ or J???
another question:
CFORCE is a force by length unit? -->(N/mm)??
Please, help me.
another question:
Please, help me.
RE: Units of Kinematic Energy
mm for length
sec for time
tons for weight
then the energy is given in Nmm, which is mJ (milli Joule)
Abaqus has no built in unit system.
CFORC is contact force per area. The area must be defined in the model. Default is 1.
Pam
mm for length
sec for time
TONNES (metric) for weight
Cheers,
-- drej --
youre right. Have to improve my english
Pam
I do not know very clearly that CFORCE is a force per area and that I must define previously this area. In my problem, I have two solids (a rectangular plate and a impactor) that makes contact after dropping to the impactor from certain height. I have defined the superior surface of the plate and the inferior one of the impactor with the Module --->Interaction in Abaqus /Explicit.
Is this sufficient one? I must define something more?
Thanks in advance, Irene Mengual
