linear tolerances of ASME y14.5M 1994
Hello anyone,
I don't want to buy the whole spec just to find out what the tolerance charts say.
I have a dim that specifies 35.0mm. The tolerance is specified in accordance with the 1994 spec, but none of us know what the +/- tolerance is under the spec.
Can anyone please help?
RE: linear tolerances of ASME y14.5M 1994
If your part has a 35.0mm dimension, it is up to you to figure out what the tolerance needs to be in relation to its mating part.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 2005 SP0.1
Chris
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Thanks again.
