Safety excess flow check valve
Does any one know that where I could find a Safety Excess Flow Check Valve or "Velocity Fuse" for compressed air?
Many thanks,
Carrie
RE: Safety excess flow check valve
Thank you for your reply. The hose Dia. is 3/4".
Thanks.
Circle Seal uses the term fuse valve.  Malema valves have a manual reset.
John
John,
Thank you so much. I checked both. From the Tach. Data, Maleme looks better to us.
Carrie
REGO excess flowcheck valves are also used.
The more you learn, the less you are certain of.
