config.pro setup to preview drawings
What is the config.pro setup to get the drawings preview when I use "File Open"- "Preview". I can see the ".prt" and ".asm" files but I can't see the "drw" files.
Thanks!
Thanks!
RE: config.pro setup to preview drawings
The config.pro setting is save_drawing_picture_file "embed".
If I recall, this will not work until you have saved the drawing once with this setting, so this will not work on any drawing previously saved without this set.
Tofflemire
ediushu
