Access denied
Access denied
Is this some sort of a setting problem?.
Under "HELP"
i.e: Dimensions - properties - name
Access denied. "INTERNET EXPLORER SCRIPT ERROR"
Under "HELP"
RE: Access denied
RE: Access denied
Also, use SP 0.1 for SW 2005--that will help with using Windows XP SP 2.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
RE: Access denied
What do you mean by having an extension reapplied within explorer.
RE: Access denied
Show Dimension Names is unchecked
It is located under Tools, Options, and is on the System Options Tab.
I hope this is what you were looking to do.
RE: Access denied
RE: Access denied
What I meant was that sometimes after moving to XP SP 2 you will find certain "plug in" applications blocked by default when using Explorer and may need to do certain things (such as reinstall) those plug ins (such as flash and other plug ins that Explorer uses) to get them to function again. This is because of the increased default security settings within XP SP 2.
Jeff Mowry
