`Failed to save document' in Solidworks
about 20% of the time, documents (.sldprt ; .sldasm ; .sdldrw) `failed to save document'.
To try and resolve the problem i have tried different network permissions, from user to administrator.
Tried 4 different PCs from a 1.7 celeron to dual Xeon rig.
Tried using a differnet network cable.
Tried using openGL.
Tried using different VGA card.
Tried using different VGA card drivers.
Tried re-installing more than once (with anti-v disabled!!)
Tried making all the files read and write enabled.
After six months I am TIRED of trying, can someone please offer some help?
RE: `Failed to save document' in Solidworks
Have you tired to a modify on your install?
What video card are you using?
Have you had someone try your files on someone else's machine and not one you hooked up to your area on the network? If you are getting this on all the machines then it's the files most likely and you should contact your VAR for help in determining this issue further.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Video card is ATI FireGL X1 with the recommened drivers.
Dual Xeon 2.8, 1024 eec ram, raid0 2 X samsung spinpoint 160GB.
We have four seats of SWs, i have successfully opened the same files on other machines with no `failed to save document' error appearing.
The VAR sent a SWs expert and a network expert.
They have no clue how to solve this prob.
Any input would be helpful.
Try saving your files to your hard drive and see if you still have the problem.
I have tried to save the sames files on my own HDD (c:\)
sometimes it saves, sometimes it don't.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 2005 SP0.1
FAQ559-507
FAQ559-488
FAQ559-908
If you are the only one in your group having this problem, then it leads me to believe its either your installation of SW, or something in your hardware set-up that is the root cause. What version of SW (& SP) are you running, and on what OS and version?
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
http:/
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Windows cannot determine the user or computer name. Return value (1722).
this is happening approximatley every 15 minutes.
could this have something to do with it?
(i am not holding my breath)
The system failed to register pointer (PTR) resource records (RRs) for network adapter
with settings:
Adapter Name : {B3843889-8FB5-4612-A0C6-900FEB834B5D}
Host Name : DrawingOffice
Adapter-specific Domain Suffix : headquarters.local
DNS server list :
xxx.xxx.xx.xx, xxx.xxx.xx.xx
Sent update to server : None
IP Address : xxx.xx.xxx.xx
(addresses taken out for security)
The reason that the system could not register these RRs was because of DNS server failure. This may be due to a zone transfer lock on the DNS server for the zone that your computer needs to update.
You can manually retry DNS registration of the network adapter and its settings by typing "ipconfig /registerdns" at the command prompt. If problems still persist, contact your DNS server or network systems administrator. For specific error code information, see the record data displayed below.
Ownership of the volume ID for C: has been successfully claimed. This volume ID is used by Distributed Link Tracking to automatically repair file links, such as Shell Shortcuts and OLE links, when for some reason those links become broken.
Maybe if Solidworks had a better way of informing the user what the problem may be. "Failed to save" is a bit vague and caused by many things.
Jason Capriotti
Smith & Nephew, Inc.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Jason Capriotti
Geuss what? The usual happened `failed to save document'
It seemed to work ok all day yesterday, but this morning it don't. I had a look at the application event log;
because the caller is not properly authorized to make this call. The COM+ application is configured to use Application and Component level access checks, and enforcement of these checks is currently enabled. The remainder of this message provides information about the component method that the caller attempted to invoke and the identity of the caller.
Destination of the rejected call:
Application Id: {02D4B3F1-FD88-11D1-960D-00805FC79235}
CLSID: {182C40F0-32E4-11D0-818B-00A0C9231C29}
IID: {47CDE9A1-0BF6-11D2-8016-00C04FB9988E}
Method #: 7
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
You have all been very helpful, thank-you.
Scott I switched-off save auto recover, and i moved my backup directory to my own HDD, no effect I'm afraid.
Thing is, I have a gut feeling this is
the windows 2000 professional configuration.
Considering that my event viewer is logging wierd and wonderful error messages everyday, I reckon it's the WIN2K.
I have sent my VAR the details from my error logs, heres hoping!
Thanks again for the help.
Jason Capriotti
Just a thought.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
If you read the initial post you'll see that avenue has been covered.
Do you guys have win2k? If so, what permissions do you have, did you install SW yourselves?
Do you have PDM works?
Do you save over a windows network?
What about all the error logs, isn't there a strong case that the server and client computers are not properly configured?
I am ready to go out and buy an Etch-a-sketch!
Last summer we got a new Win2003 server and these "Failed to save document" warnings started to appear. Back then, the workstations were running WinNT and SW2001+.
Then in October the new Dell workststions were upgraded to WinXP Pro with SW2005SP0.1 and the random errors still appear.
No rhyme or reason, very intermittant and random, and nothing in generated in the Event Viewer logs when they do occur.
Similarly, we also get a "Failed to print document error" everytime we print to the HP plotter, but if you ignore the error, the document plots anyway.
If we EVER solve this, we'll let you know.........
Remember...
"If you don't use your head,
your going to have to use your feet."
We get the exact same error with our HP 450C plotter. I tried every setting I could think of to correct it, nothing worked. Just ignore the error and eventually it plots. For a while I thought it was a memory issue, but that doesn't seem to be the case. Just thought I'd let you know you're not alone with this.
Chris
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Event Source: MRxSmb
The redirector failed to determine the connection type.
All the SW stuff was move to my HDD, and the `FAILED TO SAVE DOCUMENT' error is still happening.
The only thing that has been common all this time has been WIN2K and the error messages that i have been receiving in the event viewer.
If it is a process of elimination to find the fault then the only thing remaining that has not been changed is WIN2K.
In particular the permissions and DNS setup.
I could do with a WIN2K expert giving me some advice.
The solution to this problem was not found.
The facts are, we don't not operate DNS or DCHP on our WIN2K network, maybe this could be the problem.
Could it be a throughput problem, maybe,
Whatever it is, I don't care anymore, all the SW files have been transfered to my new (yes another one)PC and i have been taken off the network domain.
I have not had anymore failed to save problems since.
thanks for all the replies guys, if you ever get a solution to this, you have my congratulations!
regards
fedup SW user
