Initial Conditions or Boundary Conditions?
In a thermal problem, if an electronic heat generating device (100Watts) is inside of a cabinet and initially the air in the cabinet and outside the cabinet, in the room, is 72F, before the device is turned on, what would be the boundary conditions and what would be the initial conditions? The cabinet is sheet metal. There are no fans. The front and rear doors of the cabinet are perforated 64%. The cabinet sides, top and bottom are solid (no perforations). I am using an FEA called JLAnalyzer.
RE: Initial Conditions or Boundary Conditions?
