Panning and Zooming with Intellimouse
I have recently purchased a new machine at home with a wireless mouse. I noticed that the mouse does not seem to have the same response time as my wired USB mouse at work. For this reason I switched out my wireless at home with a wired. Everything seems to be working ok with the mouse except for panning with the scroll wheel. It seems that if I am zooming in or out and then quickly try to pan it does not activate the command on the first click. It almost always seems to grab on the second click. I have tried two different mice with the same result which leads me to believe that it is not them.
So here are my questions. First is there a setting somewhere that could be controlling this sensitivity? Second is there a specific mouse that AutoDesk recommends for optimal performance. I checked their web site with no luck.
Thanks in advance!
Thanks in advance!
RE: Panning and Zooming with Intellimouse
"Everybody is ignorant, only on different subjects." — Will Rogers
Mouse always functions correctly after I do this.
