Looking for source of Air-->Water heat pump
The application is radiant floor heating. The envrionment is southern Oregon. Must operate efficiently with ambiant outside temperatures in the 30 - 60 F range with 40K BTU at 30 degrees. There are numerous swiming pool heater vendors supplying heat pumps, but most all shut down at the first sign of outside coil frosting up (approx 45F). Any suggestions?
thanks, -john-
thanks, -john-
RE: Looking for source of Air-->Water heat pump
Florida Heat Pump
plus others stated above.
Or you can call me, I'll build you one. I'm in Southwest Idaho (Parma).
Clyde
McQuay comes to mind as another good name.
www.mcquay.com
