What is "Slab-on-grade"?
I have a besement with 2 meters below ground. Is the slab of this besement floor(-2m) a slab-on-grade?
Is the slab of the basement ceiling a slab-on-grade?
(assuming the ceiling slab is level 0m with thickness 200mm).
Which is slab-on-grade?
RE: What is "Slab-on-grade"?
I qualify my answers somewhat because some people use these terms slightly differently, which yes can lead to some confusion. But if you were to say a slab on grade or suspended slab, this is what most people in the field would expect.
