E1055: Unable to open 'windows.h'
Why would any compiler or linker be unable to open Windows.h?
Code runs perfectly in VC++ but when I try to run it in MATLAB, the VC++ compiler cannot find "windows.h".
Any ideas?
TIA
RE: E1055: Unable to open 'windows.h'
Are you sure all the paths are correct?  If it can't find it, it must be because it's not on the pathlist
TTFN
Problem solved.
It turned out that the file did not come with the compiler.  I had to install the latest version of the compiler to get its own version of windows.h.
Thanks.
