DIN (European) Standard Pipe-Flange Dimension
I'm working with pipe & pipe flanges. Recently I posted a request for an unisual pipe size, and got some WONDERFUL replies! This time I'm working on something related, but a bit different. I've just encountered a need for some info based on the European "DIN" standard for flanges.
Specifically, the Flange I'm working on is a DIN-2635 80mm PN-40 Raised-Face Weld Neck Flange, and I need to know where I can find a table or diagram for the height & diameters of the raised faces. (NOT the OD or bore diam, etc., I have tables for all the other standard dimensions). I lack this one piece of the puzzle.
C. Fee
C. Fee
RE: DIN (European) Standard Pipe-Flange Dimension
http://www.heco.pl/flansche/2635.htm
"Everybody is ignorant, only on different subjects." — Will Rogers
the german translation is "Vorschweissflansch".
Infos: http://m
Lothar
ADT 2004
ACAD 2002
Thanks!!
That's EXACTLY what I needed! I got a document from my Engineer who received it from his client, and that one piece of information was not included. I compared what you guys sent me, and the puzzle-piece was indeed not included in my info, so this made a big difference. My engineers have all gotten used to me being able to deliver complete designs based on (sometimes) woefully incomplete input, and AGAIN posting here helped me come through!
Thanks-
C. Fee
I'll be able to use the info provided, but a table that has headings I can read would be good, too.
Thanks again,
C. Fee
