Sanitary Fitting -Standard Design
I am looking for the standard or technical document that descibes the machining details for these fittings.  For example, I need to design a  custom ferrule to mate to a standard sanitary ferrule and need to obtain the o-ring groove details etc.  Any help appreciated.
Ron
RE: Sanitary Fitting -Standard Design
Thank-you very much, there was a lot of good info there.
The gaskets pcitured there look different than the ones I am using - those have an added lip on the outside.  I am not sure if this is the British Standard difference from the 3A standard I am looking at or not.  I have since found http://www.3-a.org but the standards there do not seem to list the information I seek.
I invite further information if anyone has more, specifically if it is associated with the 3-A standard.  Thanks again hankroach for your links!
I believe that you need 3-A standard 63-03.
