VFD on Compressor
VFD on Compressor
I have a 60 HP compressor, I don't need such a large compressor, will a VFD reduce the HP? Can I fit a VFD to this thing?
-mech
-mech
Quote:
Work Hard and Work Smart
RE: VFD on Compressor
If it a screw operated in parallel with other machines, you may need to look more closely.
-mech
The concern is whether it would surge - but you would know more than I might about the characteristics.
mech
I've spent 2 days in meetings dealing with a large (30,000 hp) centrifugal natural gas compressor on VFD's & my brain is a little tilted -
In reality its the reduction in the amount of work required (cfm, pressure, etc.) that results in the reduced horsepower.
pennpoint
programed you cannot kill your motor no matter what happens to your power or compressor. Your motor will run much cool-
er and use less power even at 60 hz. The compressor will have to be positively unloaded on start-up with silenoid
valves on both stages. They can be controlled with any vfd. I currently use around 40 hitachi vfds now and they will not die, even after 11 years!
Some darwbacks I presume are,
1. Ineffective lubrication, if the oil pump is connected to crankshaft.
2. Increased vibration due to imbalance at other speeds than designed.
I saw and used good many refrigeration chillers(screw and centrifugals) with variable speed application. I have reservations for using VSDs with screw air compressors. Proper receiver sizing, minimization of leakage and correct usage pressure with compressor on/off(or load/unload atleast) will give better results and at reduced investment.
PS: Power consumption reduces if we reduce mass flowrate through a compressor.
"Venditori de oleum-vipera non vigere excordis populi"
