Autocad 2004 2005 installer stops while installing, no error codes
When I try to install autocad everything works fine, typ serial, user, companie, etc etc if after that the actual install begins cd-rom stops spinning en nothing happens exept CPU 100%, no error codes are displayed in windows or logs. 2004 has always worked in a previous installation of windows, now on all the computers I have (8) the same problem. All are running XP with all the last updates installed.
I need help desperatly, i can't make changes to my suspension design, and the drawings are due tomorrow else we wont have our part ready for the new racing season
RE: Autocad 2004 2005 installer stops while installing, no error codes
"Everybody is ignorant, only on different subjects." — Will Rogers
I reckon your problem is with the XP SP's ~ especially as you mentioned that it installed without any problems previously.
I'm using Inventor, but all the autodesk products were exerting the same install issues. I broke my install of IV Pro (lost all the modules), and couldn't uninstall much less re-install or fix the problem.
There supposedly is a hot-fix, but I haven't had the guts to install it yet.
http://ww
There should be something on the microsoft web-site, but I couldn't find the hot-fix there.
Yes justroln, CPU usage is 100% taskmanager says the install is "running" and not "not responding". I can leave the install going on for hours, but that does nothing
htt
A short-term solution to DEP incompatibility is to disable DEP. Disabling DEP is a security risk, and will increase the vulnerability of your computer to certain types of attacks, but no more so than was possible under Windows XP Service Pack 1, which did not include the DEP feature.
If you choose to disable DEP, we recommend that you try to update all your software and drivers to Windows XP SP2-compatible versions as soon as they are released, and then re-enable the DEP feature. DivXNetworks will be releasing SP2-compatible versions of all affected products shortly. We also recommend the use of up-to-date anti-virus and firewall software at all times.
How to disable DEP
To disable DEP, perform the following actions:
* Click Start -> Run
* Enter Notepad %SYSTEMDRIVE%Boot.ini
* Under [operating systems] replace the parameter /NoExecute=xxxxx with /Execute
Save the Boot.ini file
* Restart your computer
IMPORTANT: Save a copy of your original Boot.ini file as a backup before you make changes!
You can decide for yourselves what you would like to do of course. The DivX web page is worth a visit, as at the bottom of the support page they provide a notify by email button, to automaticaly make you aware if this page is updated.
The original site is h
Hope it helps.
I've got the same problem with the Autocad 2004 installation using XP+SP2...would be very nice if you could make my dreams real and upload the file and insert the link here!!
I DO need it
Thank you very much!!
The english files can be found on my user space
http://
copy both files to a folder and execute "WindowsXP-KB885898-x86-ENU.exe"
Can you let me know on javaansejongen at gmail dot com?
Thanks in advance!
I no longer have XP (upgraded to 2K) but that fix "may" be usefull at a later date. Unfortunately the link is no longer valid. Can you repost it, thanks
Have same problem as you did. I desperately need that hotfix for autocad english version, bat your link doesn't work any more. Could you please apload it as soon as you can.
ht
The english patch:http
Here are the links, sorry it took so long but I changed the website name last thursday. That's why the links didn't work.
Happy drawing!
Lets see if all goes well !
javaansejongen
Well... the reason i don't do it myself is... exactly why it is needed...
If you can help... tank you!
