Neoprene and JP-4 Jet Fuel
We are in the process of designing an assembly that must use a vibration dampener made of neoprene. This assembly will be used in an aircraft and will be obviously exposed to fuel vapor. I have done a little searching and see that some protective gloves made for handling jet fuel are neoprene. However, the unit will be exposed to the vapors over the life of the aircraft (or the assembly) and will be experiencing temperatures from -40 to 71°C. Does anyone have knowledge if this being an unadvisable combination?
RE: Neoprene and JP-4 Jet Fuel
