Masonry Wall - Pilaster
I am designing a masonry dumpster enclosure 50x20x10 (tall). Is there a rule of thumb about pilaster placement on the wall? Is there a reason to use pilasters instead of designing a cantilever wall? Thanks in advance for the help.
RE: Masonry Wall - Pilaster
I see no need for pilasters unless the particular code that you are dealing with requires pilasters.
