Access to a device at the ceiling
Hello all,
I am facing a problem and I think I can use some good advice. We have natural gas detectors installed at the ceiling of the building and not near the walls. The height of the ceiling varies from 6 to approx. 9 m. In order to have access to these detectors for periodic maintenance, we have to use portable ladder, which is leaned against the secured bridge-crane to get on the bridge-crane. Then, standing on the bridge crane we can do the job.
It seems to me that we could make it safer by getting the gas detectors at the floor level. Has anyone seen a system where the device (similar to a gas detector) is able to be lowered and then lifted back (perhaps by wire). Provision should be given to a way of winding the power and signal cable of the detector. Such a system should be explosion proof and combatible with the bridge-crane which passes approx 0.3 m to 2 m lower than the detector (the ceiling is inclined).
Size of device approx.: 0.30m X 0.30m X 0.30m
Weight approx : 10 kg
Number of gas detectors : 16 (in my area only)
Frequency of lowering/lifting : every 6 months
Any idea will be appreciated.
Costas
Costas
RE: Access to a device at the ceiling
Anyway, thanks.
Are there other ideas?
Costas
