Torque required to backdrive planetary gearbox
How do you calculate the amount of torque required to backdrive a gearbox and motor?  I need to find this for a three-stage planetary with a servo motor attached.  The system will be powered off and we have to manually move the instrument back to home.  Thanks!
Norm
RE: Torque required to backdrive planetary gearbox
At first I thought it would be simply the output torque of the unit, but that would be way too much required (?? wouldn't it??).  An exact answer would probably involve the your max backdrive rpm requirements, reverse gear ratio, the calculated torque to turn the rotational inertia of the internal components (sometimes listed in gearbox catalogs), the torque to overcome friction of the internal components (call God, he knows this one...or you can fudge it), and the torque required to turn the servo motor rotor inertia through the reverse gear ratio(listed somewhere in a catalog, God can help with this one, too).  Oh, and assuming your motor brake is disengaged.  It may be darn near impossible to calculate it like that, it may be easier to call the supplier's Applications Engineering department and dump the question on them.  Or put a big ole cheater bar on that bad boy and tug on it until it moves.
TygerDawg
Hi Norm1961,
  As pointed out above, the backdrive torque is going to depend on alot of variables, primarily the combined reduction of all of the stages and the reflected residual torque or friction all the way back to and including the servomotor.   Based on my experience trying to backdrive a two stage planetary, 64:1 total, you are in trouble.  You may end up twisting the output shaft off before backdriving occurs.
--CCW
I would think that you could use
the reciprocal of the individual
gear efficencies times the gear
ratio times 1/20th the output
of the motor might be a good
approximation.  Too bad you cannot
reverse the current in the motor.
You might want to put on a projected
moment arm and test the pull at
that radius to find out.
In the absence of friction and churning, the backdrive torque is only a function of the reflected inertia and the time it takes to come to speed so that you can determine its acceleration. Usually the inertia at the motor shaft would be the predominant inertia and its reflected value would be :
Irefl=Imotor*(n)^2 or the inertia of the motor x fwd gear ratio squared. For example if it takes 10 seconds and the acceleration is constant and the speed at  the turning point is ramps up to 10 RPM, then the acc=10/10*2*pi/60=0.1 radian/sec^2.
Further, if the gear ratio is 100:1 and the motor inertia is .03 in-oz sec^2, then the torque due to motion for 10 seconds would be:
.03*100^2*0.1=30 in-oz , which is negligible.
The main torque would be to accomodate friction and churning. You could get a handle on this by running the system at the design speed and from its inefficiency determine the loss of power after subtracting IR losses.
As a simple example, suppose we have a DC motor at 24V putting out 1 amp of power under no load and having an armature resistance of 1 ohm. Then the loss of power at 1000RPM (consistent with the above example) attributed to the friction/churning is 24W- 1W= 23 W =23/746*550=17 ft-lb/sec. Since the input speed in our example is 1 RPM, equating the mechanical power  to 17 ft lb/sec I get
17=T*1*2*pi/60 and
T=170 ft lb, which is quite a bit but not necessarily realistic.
Norm, if the gear ratio is serious enough to justify three planetary stages, you will have to do something other than backdrive the output shaft.  Seal friction on the input shaft will immobilize it.
Consider manually controlled 'jog' inputs to the servomotor, or a round 'safety' handwheel on an intermediate shaft.
Mike Halloran
NOT speaking for
DeAngelo Marine Exhaust Inc.
Ft. Lauderdale, FL, USA
I have done a machine with a 100:1 planetary reducer and it was easy to backdrive.  Of course you had to un-plug the power leads going to the servo motor so it would not regen brake.  I don't know if you can get a servo drive that does not default to regen braking when power is off.  You could add a relay I suppose.
Could you add a manual detent/pin clutch in the drive train?
Barry1961
