Toolbar frustrations
I've just about given up on trying to keep the toolbars in a specific location.  Seems everytime I put one where I want it, it moves around when I activate another workbench.  I've tried locking them but that's not fixing the problem.  Right now I just keep the Standard, Workbench, View and Select toolbars active.  It seems they are available in all workbenches.
My question is, is there a reference available that shows the mapping of commands under the top drop down menus?
Thanks...
AJT
Manufacturing Engineer
The Boeing Company
St. Louis, MO
RE: Toolbar frustrations
dear friend,
one more option for the same is to type "c: reqd command "
in the command prompt available at right hand bottom corner.
eg to create a sketch type c: sketcher or to create pad
type c:pad (if you want to know the command name just bring the pointer near the command and you will see the short cut near the command prompt.
Amit
Even though the toolbar name is the same, each toolbar maintains it's position information separately for each workbench.
