DONT LAUGTH BUT...
DONT LAUGTH BUT...
How do you open a second sheet? when I click down on the sheet1 and add sheet I get a blank sheet, so how do I get my drawing border/ template on?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: DONT LAUGTH BUT...
When start a new drawing and you used the default SW drawing template you get the option of picking the sheet used. If you cancel then the sheet will come in without a Sheet format (Title block). If you add a second sheet from there, then you not get a title block by default, but you can still pick it in the menu given. If you click cancel then you would not get one.
If you use a template that you made and it has a sheet format on it (Title block) then you add sheet 2 you get the same menu as before. You can pick the sheet size and border to use. You toggle the sheets like mentioned above.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
thanks again!
