Problem to installing proe on winxp
Hi all.
I have some problems installing proe.
I have a network card integrated on the motherboard but when i launch the setup installation of proe, in the main window it appears that it is unable to detect the network card.
thank to who could help me.
hi
hi
RE: Problem to installing proe on winxp
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Is your HD formated to NTFS?
Ben Loosli
Ingersoll-Rand
If go into the regediter and set the number name on the card you are using to lowest value.
HKEY_LOCAL_MACHINES\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\NetworkCards
If that don’t work tray to disable media sense.
htt
Shutdown firewall software, do not install Licensed Server (ignore FlexLM warning), and then install. The program doesn't work with firewall on or while you are connected to the internet.
Wildfire does not run on xp as on nt !
If search path is used the responce increase from typical 4 minutes to 2 hours.
POBang
control block--add hardware--next-yes,the hardware has been contected,next--go to the bottom,click the words"add new hardware equiment",next--install hardware i choose from the
table,next--network adapter,next--choose the microsoft loopback adapter.next--ok.that is all.
when installing wildfire,enable the virtual network card.
that will be ok.
