Wildfire/Adobe PDF Question
When saving the plot as a PDF document, is there a way to change the automatic filename process that Wildfire is doing? Currently it just uses the filename of the drawing file, but I'd like to add a revision letter to the filename for archive purposes. Our part and assembly files have a parameter that keeps track of the revision letter ("rev"), so it'd be nice if I could modify the PDF creation process to name the new filename with this parameter tacked on the end of it.
