Assembly Cut using feature
Is there a way in pro to sweep a feature to create a cut in another feature (i.e. simulate a machine cut using a cutting tool)?
RE: Assembly Cut using feature
Novamark,
You can try the CUTOUT function. Should work for you.
-Hora
Assembly > feature > create > Cut - then your solid options would be extrude, revolve, sweep, blend, use quilt, and advanced.  This might be a little different in WF2 verses 2001
Best Regards,
Heckler
"Never underestimate the power of very stupid people in large groups" John Kenneth Galbraith
