Specs for conc open channel
I have a 2' x 2' sq and  18' long sloping reinforced concrete open channel. Any special specs for conc as conc will be in constant touch with water from Trojan Disinfection Unit.
RE: Specs for conc open channel
Check the AWWA concrete tank standards.  If they don't require anything special for that application, you shouldn't need anything special here.
ACI-318 has requirements for limiting crack width- perhaps refer to them.
