Machine performance standards
I am looking for information on interpreting the "circle/triangle/square" block used for evaluating the performance of milling machines. For example, loose gibs can cause affect the circularity of the block. I don't know if this is any sort of common standard; it has also been called a Euclid block.
RE: Machine performance standards
Richard Leu
Cascade engineering and Service
Richard_Leu@hotmail.com
Thanks for your help. Are you at Cascade Engineering in Bend, OR?
Richard Leu
Selway Machine Tool
