4" Wrench
4" Wrench
4" Wrench
I am looking for a wrench 4" supplier. This wrench must be connectable on a torque wrench.
Do you know one ?
Eric
RE: 4" Wrench
Proto makes 1 ½” drive sockets that large. We have found it less expensive to fabricate them from A514 plate.
RE: 4" Wrench
The customer wants a standard tool.
Thanks for "Proto", I was forgotten it !
RE: 4" Wrench
Thanks a lot for these web sites.
Do you know if it is possible to find a 4" wrench in crowfoot type ? ... always connectable to a torque wrench
RE: 4" Wrench
Looks like we are going to have to put (2) 2" togather to make a 4" as the largest readily available is 21/2".   Supposedly the hydraulic ratchet wrench put the large crowfoot out of business.    The ones that remember from work were for high pressure filters and were made by a company no longer in existence.  I’ve got another query out.
PS I got a 31/2" open end if you have a stretcher.
RE: 4" Wrench
unclesyd
What do you need a stretcher for, carry a dead body or what?
RE: 4" Wrench
unclesyd,
what do you call a stretcher ?
sorry I'm a french guy and I am afraid I don't understand your previous post ...
for your information, it is for high pressure hydraulic filters
RE: 4" Wrench
Pardon me as I sometimes forget the Universal aspect of Eng-tips.
BillPSU, sorry about that.
This is part of a US saying when one ends up with something
too short, like when you cut a pipe too short most of the time someone will make the comment that we need to get a "pipe stretcher".
daunay,
I should have made this a little statement a little clearer.  The crowfoot wrench was used to operate a high pressure (10,000 psi) filter when the original operating mechanism failed.  The filter had internal parts that had to be rotated to clean.
RE: 4" Wrench
unclesyd
Now I get to eat crow. I knew exactly what you meant by a stretcher. It was my feeble attempt at humor which failed.
Sorry
Bill
RE: 4" Wrench
I have called out for the appropriate stretcher many times, but Bubba was out looking for a sky hook.
Great links above, unclesyd, thanks
rmw
RE: 4" Wrench
(pipe, drill, wrench, cord) stretcher?? Oh, thats all the way at the other end of the building. I think _______ is using it. Why don't you walk down there and find out?!!!
