Problem with SAVE AS PDF
Hi all,
I am having trouble using the Save As PDF add-in in Solidworks. Everytime I use it I make sure the page set-up is correct. Then I run the command. When I check the created PDF file it always creates it in the portrait layout. The command seems to switch it from a landscape setting to portrait setting. Has anyone else had this problem?
Thanks for any help.
RE: Problem with SAVE AS PDF
Turn off High Quality setting. That fixed a problem I had.
Kind Regards,
SWCADMAN
I changed the default setting on the Bluebeam printer to landscape.
Still having the same problem.
Also turned off the High Quality setting.
Thanks for all the help.
Found out it was a rights issue. Needed to be a power user.
We were able to fix that problem by just adding to the security section of the Bluebeam printer under everyone "Allow Manage Printers" & "Allow Manage Documents".  So far that's worked for us and those people are not Power Users.
