Agitator vibration problems during mixing
I have vibration problems using an agitator in a mixing tank. The tank (1000 litres) contains water and gelatine is added. After the gelatine has been added a vacuum is applied to improve the solving of the gelatine. When using small batches, say 200 litres, large agitator vibrations at high speeds are present. These problems are new, this has not been a problem for years.
Further info:
- material shaft and blade: Stainless Steel 316
- agitator is positioned in the middle of the tank; straight downwards
- max speed: 1750 RPM
- diameter blade: 10’’
- diameter shaft: 55 mm
- tank height: 1500 mm
- distance between blade and bottom: 200 mm
- tank diameter: 1000 mm
- 2 bevels
- Critical speed appr. 750 RPM
Action taken until now:
- balanced blade, shaft, cooling fan and motor
- Reduced total deflection of agitator to 0.13 mm
- Replaced bearings
Cavitation is also a possible cause we’ve looked at… Only thing we changed is the supplier of the shaft. Both shafts are exactly the same as far as we can determine. Anyone any other ideas??? Something I’m missing completely??
Thnx!!
Grtz, Sorex
Further info:
- 2 bevels
- Replaced bearings
Thnx!!
Grtz, Sorex
RE: Agitator vibration problems during mixing
As stated above can you look inside while mixing? Is the frquency constant or does it come and go? We had a similar phenomenom occur with one of our vessels. When going through rinse cycle, low fluid level we got some wierd vibration. I looked inside and there was a vortex. When this vortex got around the shaft it caused it to start whipping, at times as much as 1 1/2 inches.
Roy Gariepy
Maintenance and Reliability Dept.
Dorlastan Fibers LLC.
Goose Creek, South Carolina USA
I'm wondering if maybe it's hollow, and has a loose slug or something similar inside it to dampen vibrations.
Mike Halloran
NOT speaking for
DeAngelo Marine Exhaust Inc.
Ft. Lauderdale, FL, USA
The shaft is completely solid. The design didn't change and the same impeller blade was used.
A possible cause for the higher vibrations can be the following: the old shaft was completely forged and the new one has a welded flange. Does anyone know if this can have an influence on the process? The material of both flanges has been investigated and the old shaft had a smaller grain, which indicates a difference in plastic deformation between the two. The modulus of elasticity is the same though and that should be the only parameter that would influence the shaft's behaviour....
We are now investigating the possibility of using a high speed camera during tests in the vessel.
If it run smooth before, that means something has changed. Isolating problem might be a start ( cost time and money..lots of it). Is this a rigid joint (no shock mount installed)?
Look at the surface finish of the shaft arounf the bearing surface. Look at the bearing itself. Improper bearing installaLion cost huge vibration issues especially when the shaft is only supported at one end. Type of greese you use in the bearing unit can play a role. If you use ball bearing, if one of this ball bearing is just slightly dent, this would create un-balance system resulting in noise (energy). When this small energy transfer to a system, it could disrupt the system natural frequency.
my 2 cent.
APH
