Line colours in SE draft
Is it possible to change or modify the line colours in SE 15?
For example,outside visible lines to black,holes to red,etc..like in Autocad.
RE: Line colours in SE draft
Hi
IN DRAFT, under FORMAT, STYLE, style type: LINE, MODIFY, GENERAL is it possible to change colors for line styles
I tried modifying the style,but it doesn't give what I want.
I need to give a different color to the inside details of a block. For eg: A blok with a hole at the centre,The outside with one color and the hole with different color in the same view.
Hi
If you use 'convert to draft view' option, it's possible to change the format of each line to your preference in 'Draw in View'. A word of caution though, you will also loose the link of the view to your part or assembly.
HTH
fwc
