GMAW Spray Welding Duplex SS
Does anyone have experience with GMAW spray welding of Dupplex SS? The procedure must meet the usual ferrite restrictions, impact tests, and corrosion tests per A 923, as well as the usual mechanical tests req'd per Sec IX. I have a FCAW that is qualified but this particular customer doesn't allow FCAW.
RE: GMAW Spray Welding Duplex SS
A source of excellent technical information regarding fabrication and welding of duplex ss is below;
www.edelst
Make sure you open a full page window to show all the publications
http://www.outokumpu.com/pages/Page____10027.aspx
There is a tremendous amount of information on stainless steel at the home website under the SS group.
This site has so much information it’s a little hard to navigate.
I would prefer FC of the two processes.
What NDT will be used on this project?
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
