angled arc
angled arc
angled arc
Hey all, how is the best way to create a angled arc. I.E, say the arc is created on the xy plane, but you wanted it to tilt in to the z axis aswell???
Sorry for the noob question
RE: angled arc
You can define the plane in the orientation you want the curve to be before you create the curve, or you can rotate the curve after it is created.
RE: angled arc
thank mate, done the transform rotate way you said. One thing, I am makeing a exhaust system, have 4 outlets, and first 2 sets of outlets contect into each other, now i have created an angled arc and sweept the exhaust diamter round and united the two together. how ever on the other two Im trying to do the same to, I sweep one circle round the arc, then when I sweep the next circle and it gives me the option to unite to the other pipe, I click unite and it asks for a name instead of just doing it.....where am i going wrong here???
RE: angled arc
Have you tried just creating all the bodies, then uniting them as a separate feature?
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: angled arc
no, would that be a better method of doing it. #
Basically i have 4 exhaust outlets (circles), they will then be pair up in to one down pipe (so left two joined and right two joined). The plan was to do this via the sweep function and unite, then the two new down pipes to be joined into one. Do you think it would be better to create the pipe with out uniting, then unite then after all pipes are dont??
RE: angled arc
Why unite them at all. From a manufacturing standpoint they are four separate tubes going into a 4-to-1 collector. The collector would be a separate piece.
Try using assembllies and put each pipe and the collector into their own detail files and then bring them together in the assembly file.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
RE: angled arc
well im creating it for CFD, so basically I need one complete volume, solid
RE: angled arc
can anyone tell me, I seem to be having a noob problem. When i select a circle, it selects another as well when i only want to select one, how do i stop this or select just one. Sorry
RE: angled arc
Is it a sketch or other feature based curve? Try to filter for just curves
RE: angled arc
If you let your cursor hover prior to picking, it will change so that you see 3 small boxes....this indicates that multiple objects are detected & should help you cycle through the objects by continued MB1 clicks.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: angled arc
Depending on the operation, you may need to change the selection intent toolbar from "add tangent change" to "single"
RE: angled arc
Im basically trying to select a circle to apply a sweep operation on, but its selecting another circle too, and i dont want it to, how do I prevent this. I dont get the 3 small boxes you suggested Tim.
RE: angled arc
To get the 3 dots make sure you have preselection turned on in your selection preferences.
But - if you only click once and it selects both circles, it sounds like preselection isn't the problem.
RE: angled arc
Nice catch, cowski....not used to such a green noob....no offense either, CFDruss. :)
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: angled arc
Hi, no offence taken, people have to start somewhere, and I learn a lot better from peoples advice than from books, rather be a team than an indiviual stuck in a book. The preselect was already on, but in the end, I just located the name of the arc and inputed it in the name box manually, seemed easy enough, and now my fist drawing ever, an exhaust system, pretty easy to you lot but im quite chuffed with it. Although there was a section of pipe that i wanted to taper between two defined circles, but it just did not seem to want to do it, any suggestions??? In the end i just had the pipe step in areas, Obviously would cause recirculation of a gas flow, but for my first drawing Im happy so far :) Now for a full engine block!!! haha, yeah right!!
RE: angled arc
When you tried the tapered pipe, was it twisting?  If so, you may wish to split each circle into 2 arcs in the exact same manner.  This will give points to align when performing the sweep & as long as you're selecting the arcs in the correct order, should prevent any twisting.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: angled arc
And BTW, we've all been new to UG at some point in time & I'm sure there's plenty of people out there who've had to go through the rigors of self-teaching.  Hang in there & keep experimenting while following along in the documentation.
You may also wish to visit here:  http://support.ugs.com/html/conferencing.shtml & look through the newsgroups, which you will need a valid Webkey account to view.  Your webkey log in info is in your UG license file, just open it with a text editor to view it.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: angled arc
Thanks tim, your help is making a lot easier that it would be with out such feedback. Mnay thanks to you all.
I the taper by, having two circles, about 5 cm away from each other, and of different diameters (small on above the larger one) I then tried to taper by selecting both the circles, but it just came up with an error. I then adding a qaudrant point to each circle and join them up to try to taper the top circle along that line, but instead of tapering it it just extruded it at an angle??
RE: angled arc
If it is just a straight pipe that you want to taper, there are a number of options available. The extrude command allows you to specify a taper at creation time, or you can do a straight extrude and add taper later (with the taper command, if using taper from edge - only select one circular end of the pipe), sweep along a guide, revolve, you could create it with freeform through curves or ruled, and there is the freeform swept feature (and there are probably a few options that I missed).
Your options narrow considerably if it is a bent pipe that you want to have tapered. If this is the case I would recommend either freeform swept or through curve mesh.
RE: angled arc
thank cowski, i see what you mean, I didnt think about the revlove command, that would probably be the easiest. thanks mate, your a star
RE: angled arc
So this is sort of like a cylinder with draft applied?  If you can, create a cylinder & add draft instead of trying to use the 2 circles.
If you don't have enough known info for the cylinder, then instead of putting points on the quadrants, TRIM the circles so that they are both 180 degrees, then mirror the resulting arcs to get 2 arcs making a complete circle.  Make sure you perform the trim at the same location for both circles.  Once you have that, the Freeform Feature called Through Curves will give you what you want unless you have a guide path that is not straight.  Refer to following image:
I made the 2 arcs different colors to display the trims for you.  Just select the curves in similar locations & everything should align OK for you.
If your guide path is not straight, you want to use the Freeform Feature called Swept.  When you use Swept, you will have to have a guide or path curve that defines the path the circles are swept along.  In the following image, I made the surfaces translucent so you could see the guide curves, which are orange.  Again, select the circles in similar locations to avoid twisting about the guide.
Hope this helps.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: angled arc
CFDruss,
In addition to Cowski & Tim's valuable input, if your circles are coaxial, you can simply create a cone (Form Feature->Cone->Two Coaxial Arcs.) This saves a couple steps if you have a straight guide path and won't need to modify tapers later.
