Water cooling in a vacuum
Here is the deal, I have a copper shield in a vacuum that is exposed to q=0.69kw of radiant energy. I need to cool this shield to prevent any warpage. I am going to weld copper tubing to the shield to use for water cooling. So the heat will be removed from the copper shield via convection. So I need a convection q=0.69kw. The problem is I dont know the temp of the shield, I have the temp of the water, the surface area is under my control to be whatever is needed. I dont have flow yet but will after friday. Can anyone lend a helping brain?
RE: Water cooling in a vacuum
Also I don't understand how you could know what the water temperature will be without knowing the flow rate. Again, there's another formula for estimating this. Let me know if you are interested.
Now back to your question: shield temperature
If you know the water temperature, that reduces the effort to finding the thermal losses between the water and shield. The formula for this isn't simple, though. The losses depend on the geometry of the assembly (shield thickness, distance to cu tube). If these losses are low, the shield will only be slightly hotter than the water. If the shield is thin compared to the distance to the copper tube, then the shield temperature will not be uniform and warpage could be pretty severe.
ko (www.ecooling.biz)
First of all, if you can obtain convection in a vacuum you will be the first one in the Cosmos. No one, to my knowledge, has ever succeeded in moving molecules where there are none to begin with. What you must be referring to is conduction, not convection. The radiant heat collected by your copper shield will be transmitted (in a vacuum) to your watercooled tubes by conduction.
Is this an industrial project? Or is this a lab experiment or problem? How do you sustain a vacuum under flat glass? The glass thickness must be great. Please give us full details of the basic data and specific scope. Otherwise, I would have to consider this an academic exercise.
Art Montemayor
Spring, TX
I know the original temperature of the cooling water. I will be measuring the flow rate when I travel to the site and can measure it with a flow gauge.
I know the area of the shield. it is approximatley 23% of the area under the heat source which is being powered by 3kw, thus the .69kw value I have specified.(assuming black body to be conservative)
Not sure where the glass comment came from, there is no glass involved.
Just a little on the project background. This is a sputtering film process in which elements are sputtered onto film. The element in question is nickel, which is hit with 3kw. The nickle is then sputtered onto the film in a pattern that is produced by the shield, kind of like a stencil. The film rotatates through the vacuum on the surface of a drum. The shield must be placed very close to this drum in order to meet with pattern tolerances. If there is expansion in the shield, it could affect the pattern, or worse damage the drum. Hope this additional info helps.
Overall, I'm confused.
A sputtering process is generally NOT a thermal process, but a kinetic process, e.g., bombardment by Argon.
A thermal process, e.g., evaporation, means that there is a crucible that contains molten nickel.
So is it an evaporator or a true sputterer? If the latter, what exactly is 3kW?
Your process is presumably already running. Are they having problems attributed to warping? Why not simply instrument the shield with a few small thermistors? Or better yet, borrow or rent a thermal camera and image the shield to determine the actual temperature and distribution thereof.
TTFN
If you're unable to get probes or a camera inside the vacuum chamber, then use the water temperature to estimate the shield temp. Water temp will vary along the tube. Conduction loss from the shield to the cooling tubes will depend of the geometry (shield thickness and tube spacing)
How far away from the source is the drum? If there were substantial amounts of heat getting to where it shield is supposed to be, the drum would see the entire amount and the film would experience a large heat influx; how is that handled?
TTFN
