etchant for 304 stainless
My company has decided to do weld sample analysis in house. We have all the needed Buehler equipment to prepare metallographic samples. I have sectioned off a sample of two peices of 304 that have been tig welded. I have already ground and polished the samples to a mirror finnish
I need to know what etchant to use to see grain structure of 304 stainless steel and the weld bead between them.
RE: etchant for 304 stainless
10g Oxalic acid in 100ml H2O. Electrolytic at 6V for 1min.
10ml HNO3 & 10-50ml HCl & 30ml glycerine -- warning poison -- use fume hood. -- do not store.... (there are also modified versions of these, usin H2O instead of glycerine or adding acetic acid.
10gCrO3 in 100ml H2O. Electrolytic at 6V for 3-5min. attacks carbides.
5ml HCl, 1g picric acid, 100ml methanol or ethanol. immerse or swab for sec to 15min. Rx may be accelerated by adding a few drops of 3%H2O2
2g CuCl2 & 40ml HCl & 40-80ml ethanol or methanol. possibly add 40ml H2O. immmerse or swab for a few seconds to a few minutes.
There are definately other different etchants that can give you what you want.
DISCLAIMER: The above formulae are poisons. They can be hazardous. They can kill you. They will hurt you if you let them.
Nick
I love materials science!
You can adjust the voltage and time to get the desired degree of etching.
If you are mounting parts and have difficulty making contact either mount them as short as possible and grind through the back of the mount or attach a papper clip to the part prior to mounting. Then you just have to grind down the back until the paper clip is exposed.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
