Solder Spec
Solder Spec
Solder Spec
I'm looking for a current industry spec similar to DOD-STD-1866 which is inactive.  What is presently used for metal joining e.g. sheet metal?
RE: Solder Spec
You can look at the following:
 ASTM B 32
 Revision: 04      Chg:      Date: 11/01/04
 STANDARD SPECIFICATION FOR SOLDER METAL
ISO 9453
 Revision: 90      Chg:      Date: 12/01/90
 SOFT SOLDER ALLOYS - CHEMICAL COMPOSITIONS AND FORMS
 AWS SHB
 Revision: 3RD     Chg:      Date: 00/00/00
 SOLDERING HANDBOOK
http://www.welding-advisers.com/
