SHOULD CONDESATE LINE BE LAREGER THEN SUPPLY?
I have what I hope is a fairly simple question:
Should a condesate line be larger then the supply line?
I am not familiar with steam and boilers, I was told by a customer that the condesate line should be smaller then the supply line, and am curious as to hear other opinions.
RE: SHOULD CONDESATE LINE BE LAREGER THEN SUPPLY?
If you are new to steam and boilers, I suggest you go to the spirax sarco site ...
http://www.spiraxsarco.com
The following download gives a very good overview of steam/condensate systems.
http://www
Hope this helps,
Anton
www.pipingdesigners.com
Thanks for the helpful links.
