Autocad 2004 LT Printing Problem
I have the following problem at a client. All clients are running Windows XP Pro SP1, Autocad 2004 LT, and either high-end AMD Athlon XP systems, or Intel P4 HTs.
They have had no printing problems in the past. However, of late, when they click the print dialogue, it takes up to 4 minutes to bring the box up before they can print.
There are no problems printing Windows test pages, or out of other applications.
Anyone seen this before?
Thanks!
Thanks!
RE: Autocad 2004 LT Printing Problem
"Everybody is ignorant, only on different subjects." — Will Rogers
I typically setup a generic folder on the hard drive to save temp files and autosaves out of AutoCAD.
Make the directory, set AutoCAD to autosave there, and clear out the old backups and saves from the windows documents and setting folder.
Good luck,
Daniel
