Gas line Depressurisation
Gents,
Could any one advise a method to calculate the time depressurise a Gas line with following details:
1- Length = 65616.6 ft
2- inside Diameter (ID) = 10"
3- Pipe pressure =1200psa
4- Temp 60oF
we need to depressurise the line before starting some works on the system.
KOKA11
4- Temp 60oF
KOKA11
RE: Gas line Depressurisation
After you get below 1 atm, the flow rate is no longer choked and the blowdown time is very difficult to determine. I always try, but I'm never very close. I can get the first chunk within seconds, but seldom get the second chunk within tens of minutes.
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
The Plural of "anecdote" is not "data"
I made a few assumptions so the program will run as follows.
One 3" ID blow down stack
Lubricated plug valve in stack.
I came up with 133 minutes
Let me know if these are incorrect and I'll try it again for you.
Pat
