measurement method on hard anodised part
Can anyone share with me about the correct measurement method on hardness of hard anodised aluminium component. Thank you.
Best regards,
ct
RE: measurement method on hard anodised part
We used to do a go-no go check with either a standard file hardness test file or a knife edge. It's either hard or it isn't. Something like Knoop or Vickers microhardness can be done, but you get lots of variability due to trying to read a small indentation on a high hardness coating.
We use Vickers microhardness as quality control method on anodized aluminum.  The indentation load is usually 25 or 50 g.
