Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...These forums are an excellent source and example of the way people can help each other..."
Geography
MAFS (Chemical)
10 Jan 05 19:41
Hello
I have a question relating to the use of existing rainwater channels under highways (I´m not sure about the correct technical term for these channels, as I am a chemical engineer).
I need to pass a pipeline through (under) a highway, and was thinking of using the existing water drainage channels to do this. Howver, a colleague told me that the curent standard in my country doesn't allow the passage of new pipelines through existing water drainage channels. My question is: do you know any standard that allows for this use of water channels? How can this be done?
Thank you
Maury (Civil/Environmental)
11 Jan 05 9:03
When you say drainage channel, are you referring to an open channel such as a stream or a ditch, or are you referring to a pipe?   What type of pipeline are you going to install?
MAFS (Chemical)
12 Jan 05 5:31
In this case it is a concrete open channel, not a pipe. We intend to install a gas pipeline.
12 Jan 05 13:58
Your first concern is the integrity of the pipeline, and locating in on the surface of a concrete channel makes it susceptible to structural damage and to corrosion.   The normal method for a roadway crossing (at least in my area) is to locate the pipe line in a casing pipe.   The casing is usually steel pipe and can be augered i place.  This provides protection for the pipeline and allows it to be removed without excavating the roadway.   Surface mounting a pipeline to a concrete channel is not a gooed idea.
Close Box
Join Eng-Tips® Today!
Join Us             Close
