double chain design
double chain design
I'm designing an unique chain transmission drive. It's unique because it uses 2 chains, rather than 1. Basically, one driving axis have driving sprocket A and B. Then one driven axis have driven sprocket A and B.
Then, a chain A will run between the driving sprocket A and the driven sprocket A. Chain B will run between the driving sprocket B and driven sprocket B.
You may ask why can't I just use one chain (a bigger, stronger chain). But I must use 2 independent chains. It's essential to the application.
My question would be if this will cause any problems or a lot of inefficiency. My worry is that since a chain drive have the "chordal effect" or the "polygon effect", which causes speed variations, the 2 chains will have different speed variations at a given time (they are not in sync),
what will happen? will the efficiency/smoothness suffer a lot?
Thanks.
Thanks.
RE: double chain design
If this is a high chain speed application there may be other problems.
Cheers
Greg Locock
